TwinTurbo.NET: Nissan 300ZX forum - If you are working without a lift then a block of wood and a
Jc (Houston)
on April 29, 2011 at 5:48 AM
what were the lift points you used on the engine? (n/m)
posted by blackomega
on April 28, 2011 at 09:35 AM
floor jack works well for lifting via the damper. If you were on a lift I would just use a highstand with the same method.
possible to install BDE motor mounts with engine in the car?
blackomega
16:57:41 04/27/11
V1 or V2? V1 is supposed to fit with OEM mounts. (n/m)
Wright (Ca)
17:31:32 04/27/11
I'm thinking balls out, V2 (n/m)
blackomega
17:41:41 04/27/11
oh wait, V2 requires modifying compressor housing?
blackomega
18:06:23 04/27/11
You will have to lift the motor to remove the mounts anyway
-Grimm-
19:23:00 04/27/11
blackomega
09:35:14 04/28/11
Not the right ones!
-Grimm-
10:33:55 04/28/11
haha, damn
blackomega
11:58:23 04/28/11
If you are working without a lift then a block of wood and a -
Jc (Houston)
05:48:26 04/29/11
